20 flow
The Preacher
i've noticed it doesn't fill the home with water vapor like 12 flow did.
i cleaned a home today and it was a lot dirtier than it looked. the home owner (PM friend i clean for) said his wife was gonna freak when she she's the difference. i said ya better get it done quartly so it doesn't git like this again!!! :shock:
the wand felt real hot (i set my thermostat at 240) and it didn't steam up the home even with the A/C running!!!
i also did 3 drying passes!!!
The Preacher
...and i'm doing it with a 36 blower there Jon Luke Picard!!!
poor MArdy just couldn't cut it, even with a GreenPimped system, he thought he had to get an extention!!!
How was your water consumption?
What kind of wand are you using?
How many jets?
I've been thinking, as was mentioned many moons ago, that its not just the water flow but the water droplet size. When you go from an 02 mist to an 04 or 05 spray, the water will hit the fibres with more impact. The Law of mass and momentum.
The Preacher
How many jets?
i don't use a fresh tank so it's not an issue.
i use a PC quad jet hybrid glided
4-9505's
water consumption is still an issue unless you have an APO as well.
I'll have to try 5x 04's or 05's, see if I can move the wand any faster. I give it a nice easy flush with the 03's and getting good results.
Just don't want to go through 200gal with bigger jets when I'm cleaning it with half that water. Going for "efficient" not "overkill".
floorguy
Utah
ok but the important question....
what psi???
and a 36....shit now you got me thinking....
floorguy
Utah
oh see then i reread it and you 3 fookin drying passes..... :shock:
my 12 flow doesnt steam up the house, and i am always around the 230 range....
for shits and giggles i may have to try it though
