bright yellow wood stains
wicker furniture bled during a water damage..
Tried CTI and Sapphire's reducers along with a steamer.
only removed the carpet's color :evil:
Got any tricks other than a knife?
K P
I have better luck with an oxidizer(without heat)but I might have used a citrus solvent first,then rinsed out well(for any residule oils).
let us know if the oxy does anything....cause i think it's toAst
send in a surgeon
Maybe fly Dr Middleton in
Benton KY USA
Wicker can be stained or painted with several things, but even in a "natural" state it can leave a nasty mark.
How you handle it depends on the carpet fiber content and color as much as the stain.
Mikey;
If you have tried two reducing agents to the point of color loss . . .
then I would try an oxidizer w/enzyme on the stain.
Our Odor Attack powder with a powerful UV light does the best job on mustard . . .
which is a strong yellow dye.
Test carpet with mustard stain ( lower left corner) removed by carpet cleaners using that technique:
Bottom two after UV + oxidizer spotting:
