Converting Porty from 1.5in to 2in
Spurlington
Spurlino
I have 2 Galaxy Pro 2700 that stays at my commercial account. I was thinking of converting the 1.5 to 2in inlet - then a short hose from each to a Y to suck through 60 - 70 feet. Would that work pretty god? If so, what tool would be best to use to make a 2in opening?
My reason for doing so is the 30 feet hose Im currently using has me running the machine behind people as they are on the phones. If I can do a 60-70ft run I could stay in the main aisle and be less of a disturbance.
If you are running 2 machines, probably no need to convert anything. You just need a y connector 1 1/2 inch on the 2 Y ends going to your machines and 2 inch on the other end. You should be able to run 100 feet no problem.
Reactions: dgardner
Guys from Alabama just wouldn't understand. They're still looking for Susanna who had the good sense to get the hell out of there
Reactions: Willy P
Hole saw. I did this to a big blue Zep portable in 1979 while frantically setting up for a huge 46,000 sqft. job.
Added a 2nd vacuum, a sump pump apo, and a toilet float auto fill.
Was just trying to stay alive, thus I empathize with porty hacks.
You mean to tell me that machine didn't come plumbed with 2inch!!?
What a waste--
What is the size of the stand pipe?
Might have to improve the manufacturer's other mistakes.
Doug Rice
I own a Mytee M12 and was wondering if going to 2" would help the vac. I have a commercial account I'm going to use my TM on the first cleaning but was hoping to do follow up cleanings with my portable.
Reactions: Foothills Phil
The only way to find out is to replace your 1 1/2 inch barb with a 2 inch, (means drilling a larger hole) and try it with 2 inch hose. You can always go back to 1 1/2 hose with a reducer cuff. It makes more of a difference if your standpipe and internal connections are also 2 inch. If you are using 2 regular 2 stage vacs, it might not make too much of a difference but if you are using 2 high performance 3 stage vacs it will make a huge difference
Reactions: vibra-vacster
The stand pipe is 2inch so you should be fine with 2 inch barb/hose..
But cleaning with a TM is more productive then a porty.. unless of course if set up and hose run with TM is beyond the capabilities of the TM.
Doug Rice
The job I need it for is hard to access and I have to secure doors and park on the sidewalk in a hooty neighborhood. Once I get it clean using the TM for main hall and entry I can start using the porty and VLM on a set schedule.
Oh I didn't catch that you had 2 ports and want to use a Y to connect the 2..
I tryed this before with 2 Mytee 5s.
Oddly 1 porty would fill up with waste water but the other not so much-- seemed since they were different ages 1 port was sucking from the other's waste tank..
Be careful and aware of possible water overflow/flooding.
Bob Pruitt
Robert Pruitt
Have you seen the prop-n-lock? You would still have to park on sidewalk but you could use truck mount.
Doug Rice
Prop-Lock looks pretty slick. Kind of priced like the Zipper/Spinner of door locks. It does look like a great idea though.
Spurlington
Spurlino
I thought of that .. add a 3/4in access port with shut off to the bottom side of each porty so that I could connect both tanks with a short hose which will allow them to fill evenly .. same with the solution tank giving me a 34 gallons of water
I did wonder if each porty would fight for vacuum .. but then wouldnt they do that as they are since some have dual stacks in the recovery tank
Or maybe I should daisy chain it .. add a 2in port on the back .. kinda like the booster set up
I would do as you originally planed with a Y.
Just Keep an eye on the setup for possible flooding-- I did same with fresh water and connected the and think I had issues also.
I may have had a problem because my M5 were old and I may have replaced the vac motors with different CFM ratings-- ie. not all vac motors may not have been the same.
I bought the Mytee Vac booster and connected that to the M5 with a 5 foot hose-- that didn't work well-- It seems the booster should be farther- say 100ft--from the porty to work best.
Reactions: Spurlington
