Jun 4, 2009 #1 Ron Lippold RIP Joined Nov 8, 2006 Messages 3,373 Location Albuquerque Name Ron lippold I think I have a bad diaphram in my chem pump Please help I could use a break down if one is avaliable. thanks
Jun 4, 2009 #2 Mikey P Administrator Joined Oct 6, 2006 Messages 116,006 Location The High Chapperal rip that pos off and call Les.
Jun 4, 2009 #3 SMRBAP Supportive Member Joined Mar 29, 2009 Messages 667 Location Pittsburgh PA Name Anthony what chem pump - and are you looking for a schematic?
Jun 4, 2009 #4 C Chris Sheldon Guest Ron, I see you are in ABQ. A&R Supply has those diaphragms in stock.
Jun 4, 2009 #5 Ron Lippold RIP Joined Nov 8, 2006 Messages 3,373 Location Albuquerque Name Ron lippold thanks fellas
Jun 4, 2009 #6 ACE Member Joined Aug 22, 2008 Messages 2,513 Location Lawrence, KS Name Mike Hughes I’m not what sure about the V’s but, most chemical pumps don’t do well at high PSI. I put a high quality ball valve in front of the chemical pump so I can turn it off when I do T & G. Before that I was doing lots of rebuilds.
Jun 4, 2009 #7 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin did you look at the check valves..........
Jun 4, 2009 #8 Ron Lippold RIP Joined Nov 8, 2006 Messages 3,373 Location Albuquerque Name Ron lippold thanks Jim Ill be sure to check that.
