northern CC'ers only: ice-melt buildup
Derek
NY
Derek
how are the rest of you fellas in the north dealing with removing a buildup of the ice-melt?
here is how i treat it, but it still doesn't work as well as i'd like it:
- pre-vac w/ my Conquest.
- dry-scrub with my Cimex and it's STIFF brushes.
- cough and choke my brains out from all the dust.
- vac again.
- notice the buildup is still there, for the most part.
- bonnet clean it as best i can w/ my Cimex.
- leave frustrated.
tx --- Derek.
Acid rinse thru your TM.
Or I would try just prespraying some acid rinse product and bonnet clean it off.
:shock:
Derek
NY
Derek
i will have to try that thanx.
question tho, have you tried this successfully on those areas that have HUGE buildup of the residue?? i'm not talking the white areas on a carpet in an entrance way, but a buildup so thick that if you rub it with your hand it is like concrete :?
I guess you could pressure wash it. :?
Got a pile lifter? Rent one?
Then acid rinse followed by bonnet.
Derek
NY
Derek
hmmm never thought of pressure washin it :shock:
if my Cimex with stiff brushes cant cut thru it, i am totally guessing that a pile lifter cant touch it.
XTREME1
RIP
Ma
Greg Crowley
Pile Lift, Vac, Prespray, hand scrub with a brush, HWE
Able 1
Wi
Keith
This one was like concrete:
I just hit it with Powerburst about 1/2 hour before I was going to clean it and let it sit, then I sprayed it again and let it sit for about 20 min. and extracted.
Sticky
Living in Rochester NY this is a problem that I deal with atleast 10 - 20 times a year. I have had best results using Release Liquid Prespray(Hydramaster) and running RinseFree Liquid(hydramaster) as an extraction detergent. I have been cleaning salt build up's like this for the past few years and it works everytime.
Sticky
RinseFree Liquid™
Carpet Cleaning Detergent
RinseFree Liquid is an ultra concentrated "all purpose" carpet cleaning detergent, designed to work on the tough soils and meet the HydraMaster SafeClean standards.
Effective at removing ice melt compounds
Phosphate-free formula
Ultra concentrated, using 1 pint to 5 gallon mix tank
Made with natural citrus solvents and emulsifiers
Balanced pH of 9.5 - 10
Descales equipment while you clean
Contains no butyl, NTA, or optical brightners
Meets stain resist requirements
Gentle, yet highly effective
Release Liquid Prespray™
Liquid Traffic Lane Cleaner & Pre-Spray
Release Pre-Spray meets the SafeClean standards of HydraMaster while offering an excellent pre-conditioner that breaks down surface tension and begins the cleaning process.
Contains powerful citrus solvents
Safe on stain resistant carpets
Effectively removes ice melt compounds
Free rinsing formula limits resoiling
Phosphate free, environmentally friendly
Starts working on traffic lane soils on contact
Contains no brightners or butyl
just some general product info from hydramasters website. Hope that helps
Derek
NY
Derek
JB :p i shoulda just referred them to you LOL :lol:
thanks Keith!
i am gonna buy some Rob, thanx man :)
Lyman
Johnstown new york
Lyman
It is not salt in the ne that gives us fits. It is calcium chloride that makes a sticky residue. CC is a fertilizer that melts ice down to 13 degrees. So everybody in the ne uses this shit. I have found that a good prespray and a lot of 175 scrubing and a real flush with a couple of post cotton bonnets is the only thing that works for me. I prescrub with a ricky g tan pad and after that a cotton with green strip pad before rinsing-flushing.
-JB-
here
JB
Ya know I don't have much of an issue w/that, the few commercial acct that I do are all so regular it's not an issue, I am blessed! Delt w/it enough in the past to know whata PITA it is. :wink:
My techs were using tile and grout wands at 3000 psi to break up dried sludge; then Acid rinsed after a good enzyme treatment in the Dakota flail!!
