Wandslinger
How do you track referral and advertising? I'm sure you have to set up a field of some sort. I just can't seem to figure it out. Your help would be most appreciated.
Tom Meyer said:How do you track referral and advertising? I'm sure you have to set up a field of some sort. I just can't seem to figure it out. Your help would be most appreciated.
SuperFly said:Tom Meyer said:How do you track referral and advertising? I'm sure you have to set up a field of some sort. I just can't seem to figure it out. Your help would be most appreciated.
Tom.. Click on Invoice..
On your invoice window click in the left pane under item..
click on the drop down arrow..
click add new.. A small window opens..
Under Item name/Number type-Referrals or whatever..
fill in the description.. Rate.. Account then click OK
To see all of them or track them after the invoice is complete:
Click on Reports then Company & Financial..
then Profit & Loss Detail.. Scroll until you see
the Referral list..![]()
:shock: :? 8)
:x
:roll: :wink: :mrgreen: :|
Brian Robison said:SuperFly said:[quote="Tom Meyer":21j10ptw]How do you track referral and advertising? I'm sure you have to set up a field of some sort. I just can't seem to figure it out. Your help would be most appreciated.
:shock: :? 8)
:x
No cust. mess is at the bottom.. The left pane on your invoice/work order..
They can be customized so yours might not say item it might have
whatever you put there..
click in the left pane.. Drop down arrow appears.. click on it then
click (Add New)... Whatever you want..
I turned it on but hell I'm not using the program for invoicing anymore.
Becker said:I turned it on but hell I'm not using the program for invoicing anymore.
What do you use?
Nearly all my jobs are paid when complete, or at least an invoice is left behind.
But I still enter all invoices into QB for tracking, customer notes for repeat clients, etc.
Brian Robison said:Damn Bill, where were you 6 months ago on this subject.
I did what you said. You seemed pretty excited about it so I did it right away as to not have you over use your exclamation points.
Thanks, :wink:
