T-Jet vs. V-Jet
lesterj2
Which do you use T-Jet -or- V-Jet ?
Is there a difference between the two?
they both spray the same, Lester.
No difference in cleaning.
The only difference is how they hook to the wand
Vee jet is all one piece and screws directly to the wand manifold.
Tee jet is body, jet and cap
personally, I wish they were all Tee-jets.
because they allow for larger/better check valve strainer at each individual jet.
On some wands that use Veejets, you can't even put a strainer on the jet
Lester;
They both produce the same spray pattern.
The VeeJets are the one used more often on TM wands because of their shorter length physically.
This allows them to be used in lo-profile wands.
