Test for wax on ceramic tile
Condog
Tony
I was reading a post and read where a member didn't test ceramic tile for wax, when the floor dried there was marks where the wax came off and didn't come off.
How do you test? Is there different tests for different kinds of waxes?
Todd C
Todd
Start off visually inspecting. Is the tile real shiney? Is the grout shiney? Shiney grout is almost always a dead giveaway there’s wax. You can also take a razor blade and try scraping a tile in a corner and see if anything flakes off.
"grout isn't shiney"
Coating leave clues such as puddling, trapped hairs and dirt, scratches, slopped on the baseboard, etc.
Spend LOTS of time in tile shops studying...
If you still don't see any of the above evidence, yet you're still concerned...put a drop of stripper on the tile behind the door for 5min. If the clear liquid clouds up, you have wax on the floor
Reactions: Condog
Condog
Tony
Thank you
Reactions: Todd C
Condog
Tony
I found an article regarding testing for wood floors.
it said place several drops of mineral spirits (paint thinner) on floor for several minutes, wipe up with a white towel if there is brown or yellow residue or it feels waxy.
Second test was drop a large drop of 1/1 water/ammonia on floor, allow to sit 5 minutes. if area turns white, a floor polish or wax is likely present.
I know wood and ceramic are different, but are there multiple types of waxes that people have put on floor tile?
I haven't found anything about testing for waxes on ceramic floors. With all the collective wisdom here, I figure there are things learned I can't find any internet search.
Is visual and stripper testing the only methods I need to do as part of pre-inspection?
Scratch test too..
Reactions: Condog
