The Use of Microban Products?
What is the best Microban product to use on carpet?
Can it be actually used to "clean" a carpet or is it only an after process application?
Are there any known problems with its use...ie resoiling, residue, etc?
Can it be used on walls?
Any unique applications?
How much for the application?
Does anyone here routinely MicroBan?
What does California have against MicroBan?
So ...who here.... knows all there is to know about using MicroBan Products???
Thomas;
Microban products should used where you have biological growth.
They are registered by the EPA, which means they have been tested to eliminate a high percentage of specific organisms.
Microban QGC is a cleaner & antimicrobial.
California has enacted separate state legislation for registration of antimicrobials.
It is redundant, due to the federal registration.
Doug Cox
Delavan, WI
Doug Cox
I use X-580 before and after cleaning. I wouldn't run Microban through a chemical meter or you'll be buying a new chemical meter.
Mike Draper
38 states now have law that you must have a Extermination license in order to apply it.
