Hazard assessment list for individuals and/or multitrucks..
This is something the one and only Lee Senter put together that will be included in the upcoming new revision of the s100 carpet cleaning standards.
While it's not part of the standards it's merely helpful suggestions to keep your ass out of trouble.
YesNoN/A Control MeasuresWork Environment – Associated Hazards
-carbon monoxide from exterior truck/mounted equipment enter home?
-hoses to house secure and not a trip/fall hazard?
-entry doors can be kept open?
-tools and chemicals can be kept secure and safe for environment children, pets, and occupants, etc?
- interior floors slippery? Potentially slippery when wet? Signage posted as needed?
-interior floors can be damaged by water, cleaning solutions?
-walls, steps, cornerbeads protected from damage
-cords running through or under doors?
-emergency action plan determined and communicated?
-safety cones, wet floor signs, caution signs, hose signs needed?
-fire extinguishers available?
YesNoN/A Control MeasuresCleaning Agents
-SDS available?
-pets, children, immune compromised people present?
-placement of chemicals out of reach of children and pets?
-all chemicals compatible?
-proper handling of cleaning agents to prevent damage to surfaces?
-rust remover used? Flammables? corrosives?
-co solvents, dry solvents, solvent fabric protectors being used?
YesNoN/A Control MeasuresElectrical and Tools
-all plugs intact with ground and no replacement ends attached?
-all wall receptacle face plates in place?
-extension cords used? Lying in water?
-will cords and hoses pose a slip, trip, and fall hazard?
-ground fault circuit interrupter required?
-hand tools and wands, ergonomically, correct?
YesNoN/A Control MeasuresProtective Equipment and
-gloves required? Rubber boots required?
-eyewear required? Side shields required?
-respirator required?
-hearing protection required?
-first aid kits properly supplied?
What would Porkchop do?
Seriously a valuable tool for multi truck operators and good awareness for owner ops. Unless your name ends in Sutley. šŸ˜‰
Reactions: hogjowl
A good reminder for overworked or distracted owner operators too.
I get more than a few calls from guys who have had problems because they neglected something while multi-tasking, using their phones, or trying to deal with a chatty or nervous ā€œhelicopterā€ customer.
