Stains from transmission fluid on CGD
Condog
Tony
I have a cleaning demo where there's a trail of stains from a transmission being drug from back of store to midway point (CGD).
Someone dropped off a box with a transmission to be rebuilt, and didn't drain the transmission, as per potential customers posted literature.
Any suggestions, or better, success story on removing transmission stains?
I have a Rotovac 360i portable Ranger/CFX unit (no heat), a Trinity Phoenix, CRB, 175, and a Multiwash.
Mikey will do it with one side of a bonnet. Ultrachem Clean straight up. It rocks.
Reactions: Condog
jack zerkie
Try some straight encap Ricks or other . DO NOT mix with water. Spill,on let dwell then use stiff brush then rinse. Do not use pressure just a hose. jz
Reactions: Condog
I was told it would need a solvent.
And both the solvent and the tranny fluid could delaminate the CGD.
Have them sign a waiver.
Marty is talking about a friction burn from the transmission sliding on the carpet. If that''s true, the line you see will be melted carpet that can't be removed
Reactions: Condog
