Zee
- Joined
- Nov 2, 2007
- Messages
- 6,196
- Name
jessicasmith said:First you need to vacuum your carpet thoroughly.
choose a time to steam clean so that the carpet can get dry quickly.
Move furniture and other object off the carpet.
fill steam cleaner container with hot water.
use cleaning solution which is recommended by your manufacturer.
start cleaning the carpet from doorway, so that you wont walk on the cleaned carpet.
rinse out your solution thoroughly with clean water.
turn on the fan and AC to dry carpet quickly.
Take care not to use too much water and be sure to completely clean all the shampoo, because soap will attract dirt. Too much water can result in mildew or shrinking.
Whats the point of making these dumbass posts?????!!!!
