Vac hose config
Meter Maid
The Undetective
Dayton,Ohio
But only with a Trinity and it's reverse twist-friendly larger oscillations and 120 RPMs..
And not that effing wood floor sander that you use...
It’ll out-clean a hillbilly special and you can push it just as fast.
You can also edge and clean hard surface with it without removing a stupid washer.
I’ve already tried to explain to you The ECO has the same exact 9/16 orbit that your Phoenix has. Zero difference in orbit.
Now, speed five is 11/16 and that is unique to TOPPZZ. Pretty sure you dialed back from that because it was a stupid idea.
The difference is the stupid ass Trinity doubles as a floor buffer with the spinning, which has nada to do with oscillations.
the same 9/16 orbit you use and I use, cleans deeper when the transmission doesn’t spin the driver so fast.
Read this three times if you need to.
Bc
He'd probably ask you where the cork screw goes and you'd probably tell him.
Baby tomato was walking with MoMA tomato, and papa tomato...
Baby tomato started to lag behind....
Papa tomato ran back, squished baby tomato, and said....
Ketchup......
NO! Not a Canadian joke...
Uma Thurman, Pulp Fiction...
(Uh, it’s an AMERICAN thing...)....
sassyotto
Wisconsin
Paul
anyway, back to the original question, I use 1 50 foot, then 1 15 foot, then all 50 foot thereafter.
I have found in my area the sweet spot it running 115 feet so I have a continuous 115 foot solution hose (which works great in cold weather since there are no metal couplers to freeze) and the 50 15 50 50 foot vac sections follow
Meter Maid
The Undetective
Dayton,Ohio
Finally, someone actually helped... thanks!!
dude...you're from Ohio.
stop making the guys from 'Bama and Georgia look smArt....
I forget exactly what our set up was.
The solution line was 125ft, then 50, then 100
vac hose all 2" unless noted in this order
35ft (that we carried in) 50ft, 25ft , 50ft 2.5" , 50ft, 50ft
but assholes.
comes natural to some of us.
The rest are pretenders....
Reactions: Meter Maid
I'm considering making my first 3 hoses into just one 150 footer, because it seems that I'm pulling out that much on almost every job.
But I can do that, because I have a real truckmount.
You're welcome on receiving the first asshole comment of the day
Meter Maid
The Undetective
Dayton,Ohio
Oh yeah because it takes a huge truckmount to run 150 feet, for sure.
Bc
Matt, that’s what I’ve done with my first 100’... it got a solid connection. I also have a 50’ coil, and a 25’ coil hung up in back...
If I need shorter than 100’ (rare), I run those...
The rest of you are assholes... hilarious, but assholes.
If you want to talk about assholes, you better be looking in the mirror when you say it. The first posts were all about helping you. The thread turned sideways when some asshole got into it with Mikey about vlm. Hmmm, I wonder who that was?
Vancouver
Canadians are so female
Bring it Bambi
Meter Maid
The Undetective
Dayton,Ohio
Article 1, paragraph 3, line 7 of the MB charter specifically mandates thread drift into hilarious and assholish directions.
If you were a supporting member you would know that.
Supporting member? I don’t have the money to purchase Mikey’s opinion.
