- Joined
- Oct 6, 2006
- Messages
- 117,344
Field King 190571 Lithium-Ion Battery Powered Pump Zero Technology Sprayer, 2-Gal, White https://a.co/d/01KMcUuq
For tile and grout I mix it in a 2 gallon jug and just dump it from the jug where I need it and use a brush to spread and scrub grout lines.I have had the pump for two years. I can get 4-6 two gallon container out of a charge. Hold battery in the van for months. I use this mainly for prespray while cleaning tile and grout.
I thought you gave up on battery sprayers?I have that exact sprayer but it is a scott's. Amazon too.
It pumps air into the tank. Use it for prespraying upholstery.
I have the Scott version of that. It's low pressure, around 20 psi and low flow. I use on stairs with my Oreck when encapping buildings with stairs. Will work good for specialty products like deodorizer or applying different things but slow for pre spraying carpet. I paid $82 and have had it over a year now. I use it in the shop as well for rugs. Battery is long lasting and charges quickly.Field King 190571 Lithium-Ion Battery Powered Pump Zero Technology Sprayer, 2-Gal, White https://a.co/d/01KMcUuq
